Diy midi controller
A project log for DIY mesh conversion of a simple drum set
Pad-to-mesh conversion of an electronic drum set (Alesis DM6) using low cost toy drums
evgenyEvgeny 01/06/2021 at 15:230 Comments
After all, the project takes small turn - the pads reported in this project are excellent, so I went ahead and designed this midi module:
https://hackaday.io/project/176712-drumidy-electronic-midi-drum-controller
It is going to take some time to fill up the info, so stay tuned!
