Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Sign up Log in
BCD/Analog Clock
LED binary clock with analog meter for displaying time and date as a percentage.
miroslav-hancarMiroslav Hancar
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
2 followers
  • Description
  • Details
  • Files 3
    • View all
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
208
0
2
3
Team (1)
  • miroslav-hancarMiroslav Hancar
Join this project's team
  • video
completed project
hardware
clock microchip pic 8 bit
This project was created on 04/21/2020 and last updated 3 years ago.
Description
I designed this clock because i had a few unused analog ammeters with percentage scale and i was thinking it would be interesting to use them for displaying the time. This clock is based on Microchip's PIC16LF19175 which features a battery backed RTC to keep the time and date.
The clock is equipped with a very simple IR proximity sensor for activating the LEDs by hand. LEDs are turned off after 10 seconds to save the battery. Analog meter is driven by current source composed of DAC MCP4911, as a source of control voltage, and OPAMP MCP6031. The analog meter gradually displays percentage of day, week, month and year. Currently displayed percentage is indicated by two LEDs on the left side of pcb.
The clock is powered by a single AA cell but its voltage needs to be increased because 1.5V is too low for driving the LEDs. This is done by boost converter MCP16251 which generates 3.3V.
The battery run-time is approx. 6 weeks assuming the LEDs are activated only few times a day.
Details
Files
clock.sch
sch - 667.83 kB - 04/21/2020 at 12:06
Download
clock.brd
brd - 205.44 kB - 04/21/2020 at 12:06
Download
clock.hex
hex - 19.83 kB - 04/21/2020 at 12:06
Download
Log In/Sign up to comment
Sign up with Github
OR
The 2018 Hackaday Prize
Tix Clock Implemented In a Gem Mine Diorama
Project Owner Contributor
Tix Clock Gems
chris-chungChris Chung
Instead of showing the time like in classical type of clock with the hands or numbers, it shows you a time by displaying the text
Word Clock base on RGB LED WS2812B
simonSimon
Nixie like Clock based on Acrylic Glass
Retro Nixie
saarbastlersaarbastler
The idea for this project is to repurpose an analog wall clock to display the date instead of the time.
Calendar Clock 50 Years Battery Life 1 AA Alkaline
josh-joyJosh Joy
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "BCD/Analog Clock", please tell us the reason.
Send message
Remove Member
