Scans a magnetic fields in two dimensions
Use a HMC5883L sensor instead of the single axis Hall Effect sensor and you should be able to record more detail about the magnetic fields.
Hopefully the motors won't interfere too much with the sensor.
Thanks for the info. Yea, the direction with strength of the magnetic field at every point could give alot more information. I think the motors were turned of for every meassurement and then get power only for the movement again.
takayuki.kosaka
Riccardo
Bill Brubaker
SimpleTronic
Yes, delete it Cancel
You are about to report the project "Linear 2D-Scanner for Magnetic Fields", please tell us the reason.
