Motor
A project log for Hi torque 3d printed cheap robot actuator
Cheap 3d printed hi torque robot actuator with electronics
Pavel G.Pavel G. 04/29/2020 at 08:100 Comments
Motor theory and practice
I use brushless 5010 motor rewired as stepper motor with 28 steps per revolution, controlled by L298N module, arduino and 2 hall effect sensors
Image bellow is a 3 phase brushless motor (5010 model) with 14 magnet poles and 12 stator poles, this motor need to be rewired as stepper motor with 28 steps per revolution
Motor wiring diagram (14 magnet poles, 12 stator poles) converted to stepper motor (top view)
NOTE: Arrows lines is always on top of stator lines
Motor phases animation with wiring above visualized in video bellow
Disassembled motor ready for rewire
I use small radius PTFE tube as a helper for rewiring
100 turns per pole by 28 AWG wire (very challenging process)
Final resistance 3.7 Ohm per phase
Assembled motor (wires covered by nail polish (pole 1 marked by blue)
Motor base plate 3d Printed (small holes for hall effects sensors mounting)
2 Hall sensors ready to be mount on base plate (49E 9148G sensor)
Sensors mounted to base
Motor mounted to base plate 1st hall sensor look at stator pole 12 2nd to 9 (it should be 90 degrees)
Sensorless motor test run
Sensored test run
Motor torque test
