Project Log 3
A project log for E Paper Display & Microsoft Azure Sphere
Interfacing an 2.9" E-Paper display with Microsoft's Azure Sphere Module using Avnet AzSphere SK
gurinder-singh-gillGurinder Singh Gill 06/10/2020 at 14:460 Comments
For those who prefer something permanent rather than the clumsy Mikro Bus Interface module I had made, I am adding schematic and board design files for the interface module which only would require you to solder the standard headers to make something permanent.
- Supports Waveshare/GoodDisplay 2.9" Display Module (0.1" Headers pre soldered on the Module)
- Supports two Waveshare/GoodDisplay 4.2" Display Modules (2mm headers pre soldered on the modules) Provided that Microsoft releases an update to the spi lib for Azure Sphere so that you can define a custom pin as CS pin.
Regards & Stay Safe
