Sensor-Box.JPGIt contains the temperature, humidity, and light sensors mounted on top. This was 3-D printed!JPEG Image - 1.69 MB - 05/31/2020 at 18:06 |
Reciever-Box.JPGReceiver box. Capsense will be added to the control of the display. Uses PSoC-6 Pioneer kit.JPEG Image - 1.84 MB - 05/31/2020 at 17:59 |
Sensor-Battery-Xmitter-Box.JPGSensor control and Transmitter Box. Supports Wifi, BLE, and 2.4ghz. LORA might be an added option.Uses PSoC-6 Pioneer kit. JPEG Image - 1.88 MB - 05/31/2020 at 17:58 |
Weather Instrument Prototyping.jpgPrototyping/development environment.JPEG Image - 289.42 kB - 05/31/2020 at 17:02 |
Weather Station Instrument.jpgWeather Station instrument. Records the usual wind Speed, Direction, and Rainfall. Also the temperature, and humidity.In addition, it will record Ambient Light level, UV level, RGB Color, High Dynamic Range Digital Light JPEG Image - 1.04 MB - 05/31/2020 at 16:47 |
MMPT Solar Charger.pngFeatures (This board will be integrated into the PSoC-6)• Reverse Polarity protected solar panel input with press-to-open terminal block • Fused battery input with press-to-open terminal block • Maximum 2A at 5V output on USB Type A power output jack and solder header • Automatic low-battery disconnect and auto-restart on recharged battery • Temperature compensation sensor with internal sensor fallback • Status LED indicating charge and power conditions, fault information • I2C interface for detailed operation condition readout and configuration parameter access • Configurable battery charge parameters • Status signals for night detection and pre-power-down alert • Night-only operating mode (switch 5V output on only at night) • Watchdog functionality to power-cycle connected device if it crashes Portable Network Graphics (PNG) - 162.66 kB - 05/31/2020 at 16:42 |
