Metriful: Indoor Environment Monitor
Measure air quality, sound, light, particulates, temperature, humidity, and more. Raspberry Pi and Arduino compatible.
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Metriful is an electronic sensor module for indoor environment monitoring. It measures eighteen variables, either on-demand or on a periodically repeating cycle.<br><br>We&apos;re all spending a lot of time indoors these days - get to know your environment!<br><br>Measurements include: air quality index, temperature, air pressure, humidity, sound noise, light illuminance, particulates (with extra plug-in sensor)<br><br>Metriful accepts a 3.3 V or 5 V supply and I2C-compatible communications, so you can use it with Raspberry Pi, Arduino, or thousands of other systems. Use it to review and improve your environment, send IoT data to the cloud, or build it into smart home automation projects, context aware appliances, and more.<br><br>You can get your own Metriful board by backing our Kickstarter project:<br><a target="_blank" rel="noopener noreferrer" href="https://www.kickstarter.com/projects/metriful/sense-indoor-environment-monitor?ref=eauqcr">https://www.kickstarter.com/projects/metri
