Eurorack Power Supply Front Panel
Power supply panel with a AC switch and +12/-12/+5 Led indicator
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Repurposed Metal panel with 16 pin IDC connector for easy testing of modules.
•Simple LEDs indication with a resistor too limit the current.
•16 pin breakout for fast testing modules
-Problems-
I Had too increase the resistor on the blue LED due too it being eye blinding bright.
Having a problem with the Input jack being a loose fit.
-Caution-
If you attempt something similar make sure that you heat shrink. The AC connections and choose proper rated switches/wire for Switching AC and that your transformer has fuse. Right now this is less of a guide more of a display of my project.
