Testing the External SRAM
A project log for Retro 68000 CPU in an FPGA
Making a Retrocomputer with a 68000 CPU in an FPGA
land-boardscomland-boards.com 08/22/2020 at 12:550 Comments
Now that we have a working GCC toolchain, let's write a program to test the External SRAM.  Need to use the patch that fixes the timeout for srecord loading. Using this patched version of the srecord file.
I'm using a GitHub repo to transfer data back and forth to my PC.
Also, upgraded to Quartus version 20.1. It is very slow.
Test of External SRAM passes:
* Test External SRAM
* External SRAM on the RETRO-EP4CE15 card goes from 0x300000 to 0x3FFFFF (1 MB)
* External SRAM only supports 8-bit accesses
* TUTOR14 uses SRAM from 0x000000 to 0x000800
RAMSTART    = 0x300000
RAMEND      = 0x3FFFFF
ACIASTAT    = 0x010041
ACIADATA    = 0x010043
* Code follows
    .ORG    0x001000
* CHECK FIRST LOCATION BY WRITING/READING 0x55/0xAA
STARTTEST:
    MOVE.L  #RAMSTART,%A0
    MOVE.B  #0x55,%D0
    MOVE.B  %D0,(%A0)
    NOP
    MOVE.B  (%A0),%D1
    CMP.B   %D0,%D1
    BNE     FAIL
    MOVE.B  #0xAA,%D0
    MOVE.B  %D0,(%A0)
    NOP
    MOVE.B  (%A0),%D1
    CMP.B   %D0,%D1
    BNE     FAIL
* WRITE INCREMENTING PATTERN
    MOVE.B  #0X00,%D0
    MOVE.L  #RAMEND+1,%A1
CHKBLKS:
    MOVE.B  %D0,(%A0)+
    CMP.L   %A0,%A1
    BEQ     DONEFILL
    ADDI.B  #0x01,%D0
    BRA     CHKBLKS
DONEFILL:
* READ BACK INCREMENTING PATTERN
    MOVE.B  #0X00,%D0
LOOPCHK:
    MOVE.B  (%A0)+,%D1
    CMP.B   %D0,%D1
    BNE     FAIL
    CMP.L   %A0,%A1
    BEQ     DONECHK
    ADDI.B  #0x01,%D0
    BRA     LOOPCHK
DONECHK:
* PRINT 'Pass'
    MOVE.B  #0x0A,%D0
    JSR     OUTCHAR
    MOVE.B  #0x0D,%D0
    JSR     OUTCHAR
    MOVE.B  #'P',%D0
    JSR     OUTCHAR
    MOVE.B  #'a',%D0
    JSR     OUTCHAR
    MOVE.B  #'s',%D0
    JSR     OUTCHAR
    MOVE.B  #'s',%D0
    JSR     OUTCHAR
    RTS
FAIL:
* PRINT 'Fail'
    MOVE.B  #0x0A,%D0
    JSR     OUTCHAR
    MOVE.B  #0x0D,%D0
    JSR     OUTCHAR
    MOVE.B  #'F',%D0
    JSR     OUTCHAR
    MOVE.B  #'a',%D0
    JSR     OUTCHAR
    MOVE.B  #'i',%D0
    JSR     OUTCHAR
    MOVE.B  #'l',%D0
    JSR     OUTCHAR
    RTS
* OUTPUT A CHARACTER IN D0 TO THE ACIA
OUTCHAR:
    BSR     WAITRDY
    LEA     ACIADATA,%A1
    MOVE.B  %D0,(%A1)
    RTS
* WAIT FOR THE SERIAL PORT TO BE READY
WAITRDY:
    LEA     ACIASTAT,%A1
LOOPRDY:
    MOVE.B  (%A1),%D1
    ANDI.B  #0x2,%D1
    BEQ     LOOPRDY
    RTS
Made significant improvements to above code and checked it into GitHub here.
