MABEL.stepProject File for modifications in CAD.step - 14.16 MB - 08/03/2020 at 13:35 |
DriverGear.stlGear to drive leg sections. 3D Print 4x.Standard Tesselated Geometry - 2.55 MB - 08/03/2020 at 13:34 |
LowerLeg.stl3D Print LowerLeg.stl 2xStandard Tesselated Geometry - 2.15 MB - 08/03/2020 at 13:34 |
BatteryPack.stlHousing to hold 2800mAh LiPo battery. Only one required.Standard Tesselated Geometry - 973.76 kB - 08/03/2020 at 13:34 |
BodyPanel.stlSide panels that hold the upper servos and drive the Upper leg segments. 3D print 2x.Standard Tesselated Geometry - 1005.64 kB - 08/03/2020 at 13:34 |
BodyTop.stlTop of the Body. 1xStandard Tesselated Geometry - 302.63 kB - 08/03/2020 at 13:34 |
Housing.stlBottom section of robot body. 1xStandard Tesselated Geometry - 931.80 kB - 08/03/2020 at 13:34 |
PanBracketHead.stlPan bracket mount for head movement mechanism. Print 1x.Standard Tesselated Geometry - 1.46 MB - 08/03/2020 at 13:34 |
UpperBody.stlUpper body section. Print 1xStandard Tesselated Geometry - 1.11 MB - 08/03/2020 at 13:34 |
TiltBracketHead.stlTilt bracket mount for head movement mechanism. Print 1x.Standard Tesselated Geometry - 669.42 kB - 08/03/2020 at 13:34 |
UpperLeg.stlUpper leg section. Print 2x - One for each legStandard Tesselated Geometry - 2.01 MB - 08/03/2020 at 13:34 |
Wheel.stlWheel (Optional - own wheels can be used) - Print 2xStandard Tesselated Geometry - 744.00 kB - 08/03/2020 at 13:34 |
