Embedded Strain Wave Actuator
A high performance 3D-printed harmonic drive
We are building a high performance 3D-printed harmonic drive for use on a 3kg payload 6DOF arm. So far, most articulated robots made in this fashion lift around three times less, limiting their application to very small payloads. We think bridging this gap is necessary for the future of low-cost, open source robotics. This is our 6th revision of the actuator. For our arm, the varying torque requirements between joints led us to a modular and scalable actuator design. Ideally, each application would have a different gearbox for the respective requirement, however, due to motor choice constraints, we have chosen to develop two types: a 45:1 design (T1) with a 4008 330kv motor, and a 60:1 design (T2) with a 5065 270kv motor (in progress).
T1 Specifications:
  • 28.4n/m theoretical output torque
  • 43.3n/m tested gearbox yield toque
  • 45:1
  • 24v
  • 543g
Thermal Management:
The gearbox produces heat, from friction on the teeth and in the elliptical bearing, as well as from the motor and electronics. Unfortunately, the very fact that FDM printing works through thermal extrusion limits us to materials with relatively low glass transition temperatures. Further, to avoid contamination, we would prefer to have no external vents. We have noticed deformation under thermal load on several prototypes. With that in mind, our current prototype has fan blades on the wave generator, as well as ducts to allow airflow within the gearbox.
The spline pictured above interfaces with the 8192 CPR encoder through a hole in the shell
Filament Choice:
After some research online, we chose to print with IC3D PETG for its high layer adhesion and low shrinkage (important for gear interface). However, in comparison to prior prints in ABS and PLA, its high density surprised us. After prototyping, we are considering swapping to Polycarbonate for its higher glass transition temperature, lower density, and ability to withstand higher torsional stresses. Unfortunately, PC’s high shrinkage tendencies may pose an issue. If you have any recommendations please let me know, I'm all ears!
Lubricant choice:
PTFE was used between the wave generator, ball-cage, ball bearings, and flex spline because a few airsofting forums suggested it was the best choice for the PETG gearboxes in their rifles. If anyone has more experience with this, I’d love to hear it.
Tooth Kinematics:
As a result of the unique relative motion profile between the fixed and flex spline, we used Matlab to design a custom tooth shape to improve engagement characteristics and increase load capacity. An expired patent explains a similar approach.
Manufacturing: (Lulzbot Taz 6 & CuraLulzbot 3.6.2)
We 3D printed every part possible, including the ball cage and the lower elliptical bearing. We are currently designing a method to make the output bearing in the same fashion in the future.
Print settings were optimized for each part and custom profiles for each are linked below. Note: this is what has worked best for us, your printer may be different. We started with priority on surface quality but soon realized that structural properties were far more important. Z seams on bearing surfaces, layer adhesion, and print direction had much more of an effect on the function of the gearbox. Notable changes include a tweakAtZ in print speed from 60mm/s to 20mm/s during the layers with teeth, infill overlap percentage reduction (100% infill led to material buildup and artifacting), retraction tuning (the precise ball cage is an intense test), and support parameter changes. If you have any questions about printing profiles, message me - I’d love to help!
We are open to collaboration or employment opportunities.
SmallMotorESpacer5.STL
Standard Tesselated Geometry - 16.62 MB - 08/07/2020 at 07:50
Download
flex-spline.zip
zipped due to hackaday size limitations
x-zip-compressed - 42.36 MB - 08/07/2020 at 07:49
Download
actuator-holder.zip
x-zip-compressed - 41.53 MB - 08/07/2020 at 07:49
Download
BarHolder.STL
Standard Tesselated Geometry - 112.39 kB - 08/07/2020 at 07:49
Download
shell.zip
x-zip-compressed - 28.39 MB - 08/07/2020 at 07:49
Download
View all 12 files
  • 1
    Step 1
    Direct message me and I'll guide you through the process. Unfortunately, the design of this actuator requires a pretty complicated assembly process.
View all instructions
ice2009 wrote 04/21/2021 at 20:38 • point
can you share step file ?
John Lauer wrote 03/04/2021 at 20:40 • point
Do you guys have any videos of this thing in action? I'd love to try to build one as I've been trying to build a 3D printed robot arm as well (https://www.youtube.com/watch?v=tEbJV32GyYU). I'm making progress on moving to BLDC motors for more power. I've been using compound planetary gears, but I'd love to try our your harmonic drive.
3gfisch wrote 10/31/2020 at 09:43 • point
nice project
