Boards!
A project log for System K8
The massively versatile All-in-One computing system
knvdKn/vD 09/09/2020 at 11:253 Comments
Arrived today and look beautiful. Now expecting parts.
Goran Mahovlic wrote 10/09/2020 at 11:13 point
Yes, that is cool word! But as it can also be used for other things, like file transfer or audio - we are calling it  GPDI - General Purpose Differential Interface ;) I do not know if you FPGA is supporting bidirectional differential pins and also clock capable pin at that place, as if it does it can be used as INPUT also. We did make small mistake on ULX3S so it does not support it, we can get input only with PMOD...
Goran Mahovlic wrote 10/08/2020 at 19:16 point
It looks great! Retro FPGA! You may want to remove HDMI marking from the board if you will sell it to someone, as that is proprietary and quite expensive logo.
Kn/vD wrote 10/09/2020 at 10:56 point
Yes, thanks for the suggestion. You are right. I will change it to "Video" - a completely free word ;)
