stereoscopic_screen_with_fotoresistor2.jpgThere is a demo app located in screen directory for show a sterioscopic image, that is using the Linux Direct Rendering Interface for show a different image every vblank screen cycle (That in my case is 120HZ) Suppose to be seen the rectangle only in one lens and the circle in the otherJPEG Image - 1.14 MB - 11/25/2020 at 11:17 |
stereoscopic_screen_with_fotoresistor.jpgAs can be seen in the image, there is a fotoresistor stick in the screen for check the on-screen frame token (the white small rectangle in the screen corner). This fotoresistor is connected to the RISC-V microcontroller throw a 100K resistorJPEG Image - 1.14 MB - 11/25/2020 at 11:14 |
schema.jpgElectrical schemaJPEG Image - 777.70 kB - 09/17/2020 at 10:11 |
on_function_2.mkvFunction testx-matroska - 2.35 MB - 09/17/2020 at 10:10 |
on_function_3.mkvFunction testx-matroska - 1.45 MB - 09/17/2020 at 10:10 |
on_function.mkvFunction testx-matroska - 1.24 MB - 09/17/2020 at 10:10 |
