Using Inkscape set the document to a defined size, lets say 500px
Now we make a 250px rectangle.
Then export it as PNG, but be aware to use the same size (500px) of the whole document.
Now we can export it as PNG, but we need BMP.
I use the imagemagick tool to convert it to bmp with the following command:
convert 50mmrect.png BMP3:50mmrect.bmp
 It is important to use the BMP3 (Version 3), because this generates files with 24 bit color:
50mmrect.bmp: PC bitmap, Windows 3.x format, 500 x 500 x 24
 Without the BMP3 it generates in the newer 32Bit format, which results in a wrong results on the Anycubic. You can use the "file" command to check your version.
This is wrong:
20mmrect.bmp: PC bitmap, Windows 98/2000 and newer format, 76 x 76 x 32
 The BMP Version problem took me the most time to figure out.
The default setting of the Anycubic firmware is to scale each pixel to 0.1, so our 250px will result in a 25mm rectangle.
Bingo! So now I know how to make drawing and scale them to the output of the Anycubic.
Materials and Settings
MaterialLaser IntensityResultLightBurn Settings
2mm felt (black)45% (cut)OK
3mm black plastic
EAN:
100%
40% (engraving)
NOPEEngrave:
Cut: 2mm/s 100% 1x
Image: 100mm/s 1% LineInterval: 0.1
1mm foam rubber
EAN: 4008525160427
40% (cut)OK
2mm acrylic glas (transparent)
EAN: 4003412026695
100%NOPE
Stickable foam rubber
EAN: 4008525756163
40% (cut)OK
presentation foil (transparent)
EAN: 4250073716230
80% (cut)
40% (engraving)
OK
Cardboard 2mm
EAN: 2118251002648
100%
NOPEEngrave: 15mm/s 20
Cut: 1.5mm/s 100% 5 times, 0.4mm ZOffset
3mm Carton mousse black
EAN: 3329681936499
100% (cut)
1-2mm balsa woodEngrave: 15mm/s 20%
Cut: 8mm/s 100% 5 times
Image: 200mm/s 1% LineInterval: 0.2
