SDC file
A project log for Super custom PWM - FPGA
Make a FPGA with lots of PWM ports, all of them 32 bit, and easy to program!
sciencedude1990sciencedude1990 11/02/2020 at 03:590 Comments
# inform Quartus that the clk port brings a 50MHz clock into our design so
# that timing closure on our design can be analyzed
create_clock -name clk -period "50MHz" [get_ports clk]
# inform Quartus that the LED output port has no critical timing requirements
# it’s a single output port driving an LED, there are no timing relationships
# that are critical for this
set_false_path -from * -to [get_ports led1]
set_false_path -from * -to [get_ports led2]
set_false_path -from * -to [get_ports led3]
set_false_path -from * -to [get_ports led4]
set_false_path -from * -to [get_ports led5]
