Super custom PWM - FPGA
Make a FPGA with lots of PWM ports, all of them 32 bit, and easy to program!
Public Chat
To learn more about FPGAs, I created an FPGA that can generate a whole bunch of 32-bit PWM ports. This first version has 8 PWMs, each running 32 bit.
Please see my "first project" on how to setup everything:
https://hackaday.io/project/175642-a-first-fpga-project-spi
I used an Intel MAX10 FPGA (10M08SAE144C8G), and then a ATMEGA256RFR2 to interface with the FPGA over SPI.  The ATMEGA256RFR2 is 3.3 V, so compatible with the FPGA.
For this project, I created a SPI interface on the FPGA.  The ATMEGA256RFR2 is the master.  Since this is my FPGA, and maybe we could move away from the "slave" term, I called the FPGA the "sidekick".
Anyway, I also added a "register map" to the FPGA.  This version has 8 indepedent PWMs, all running at 32 bit, and 50 MHz.  I tried to comment the heck out of the code.  This is a complete project, so future versions could have more features.
Enjoy!
The PWM period can be from 50 ns all the way up to ~86 seconds.  The PWM on time can be as short as 25 ns.  Not bad!  :)
Below is the teraterm session between the PC and the ATMEGA256RFR2.  Register (decimal) 198 is the SPI register for output (i.e., UDR0).  Not show, I set the chip select pin to 0 (from 1).  Then, I enter 1 to edit a register.  Then, address "15".  Next, I set the 32 bit register to 2 (i.e. the period of the PWM is 2 ticks of the 50 MHz FPGA clock).  Then, I write 1 to register 16 (i.e, for the PWM to be high for 1 tick of the 50 MHz FPGA).  I highlighted the session in orange...
This gave rise to the super short PWM output on pin 41 of the FPGA (i.e., one tick of the 50 MHz clock, and a period of two ticks of the 50 MHz clock):
Next, I programmed in larger values for the PWM settings (i.e., the programmed values for the 32 bit register were decimal 1, 0, 0, 0 which will mean an actual decimal value of 16777216 ticks for the PWM output to be high, or 336 ms high), and a period of 33554432 ticks (or 671 ms).
And voila!
For interest, here is the Quartus report:
Flow Status Successful - Sun Nov 01 22:36:01 2020
Quartus Prime Version 20.1.0 Build 711 06/05/2020 SJ Lite Edition
Revision Name spi_pwm_micro_test
Top-level Entity Name spi_pwm_micro_test
Family MAX 10
Device 10M08SAE144C8G
Timing Models Final
Total logic elements 1,628 / 8,064 ( 20 % )
Total registers 923
Total pins 18 / 101 ( 18 % )
Total virtual pins 0
Total memory bits 0 / 387,072 ( 0 % )
Embedded Multiplier 9-bit elements 0 / 48 ( 0 % )
Total PLLs 0 / 1 ( 0 % )
UFM blocks 0 / 1 ( 0 % )
ADC blocks 0 / 1 ( 0 % )
  • Main verilog HDL code
    sciencedude199011/02/2020 at 04:02 0 comments
    // Main module - the ports for the FPGA, register map handling
    module spi_pwm_micro_test(
    	input wire clk, // 50 MHz clock, pin 27
    	input wire bar_ss, // SPI chip select, pin 93
    	input wire mosi, // SPI master output, pin 92
    	input wire sck, // SPI clock, pin 99
    	output wire miso, // SPI sidekick output, pin 101
    	output wire led1, // LED1 pin 132
    	output wire led2, // LED2 pin 134
    	output wire led3, // LED3 pin 135
    	output wire led4, // LED4 pin 140
    	output wire led5, // LED5 pin 141
    	output wire pwm_wire0, // PIN 60
    	output wire pwm_wire1, // PIN 59
    	output wire pwm_wire2, // PIN 56
    	output wire pwm_wire3, // PIN 55
    	output wire pwm_wire4, // PIN 47
    	output wire pwm_wire5, // PIN 46
    	output wire pwm_wire6, // PIN 43
    	output wire pwm_wire7); // PIN 41
    // Register map
    reg [31:0] max_count_0;
    reg [31:0] compare_val_0;
    reg [31:0] max_count_1;
    reg [31:0] compare_val_1;
    reg [31:0] max_count_2;
    reg [31:0] compare_val_2;
    reg [31:0] max_count_3;
    reg [31:0] compare_val_3;
    reg [31:0] max_count_4;
    reg [31:0] compare_val_4;
    reg [31:0] max_count_5;
    reg [31:0] compare_val_5;
    reg [31:0] max_count_6;
    reg [31:0] compare_val_6;
    reg [31:0] max_count_7;
    reg [31:0] compare_val_7;
    // Initial values for the register map
    initial begin
    	max_count_0 <= 32'h02FAF080;
    	compare_val_0 <= 32'h017D7840;
    	max_count_1 <= 32'h02FAF080;
    	compare_val_1 <= 32'h017D7840;
    	max_count_2 <= 32'h02FAF080;
    	compare_val_2 <= 32'h017D7840;
    	max_count_3 <= 32'h02FAF080;
    	compare_val_3 <= 32'h017D7840;
    	max_count_4 <= 32'h02FAF080;
    	compare_val_4 <= 32'h017D7840;
    	max_count_5 <= 32'h02FAF080;
    	compare_val_5 <= 32'h017D7840;
    	max_count_6 <= 32'h02FAF080;
    	compare_val_6 <= 32'h017D7840;
    	max_count_7 <= 32'h02FAF080;
    	compare_val_7 <= 32'h017D7840;
    end
    // Registers for the SPI interface
    wire spi_ready_write_data;
    wire spi_ready_read_data;
    wire [7:0] spi_register_address;
    wire [31:0] spi_write_data;
    reg [31:0] spi_read_data;
    initial begin
    	spi_read_data <= 32'h00000000;
    end
    // SPI module
    spi_interface spi0(clk, bar_ss, mosi, sck, miso, spi_ready_write_data, spi_ready_read_data, spi_register_address, spi_write_data, spi_read_data);
    // Register map in/out
    always @(negedge clk) begin
    	// Writing registers
    	if (spi_ready_write_data == 1'b1) begin
    		case (spi_register_address)
    			8'd1 : max_count_0 <= spi_write_data;
    			8'd2 : compare_val_0 <= spi_write_data;
    			8'd3 : max_count_1 <= spi_write_data;
    			8'd4 : compare_val_1 <= spi_write_data;
    			8'd5 : max_count_2 <= spi_write_data;
    			8'd6 : compare_val_2 <= spi_write_data;
    			8'd7 : max_count_3 <= spi_write_data;
    			8'd8 : compare_val_3 <= spi_write_data;
    			8'd9 : max_count_4 <= spi_write_data;
    			8'd10 : compare_val_4 <= spi_write_data;
    			8'd11 : max_count_5 <= spi_write_data;
    			8'd12 : compare_val_5 <= spi_write_data;
    			8'd13 : max_count_6 <= spi_write_data;
    			8'd14 : compare_val_6 <= spi_write_data;
    			8'd15 : max_count_7 <= spi_write_data;
    			8'd16 : compare_val_7 <= spi_write_data;
    		endcase
    	end else if (spi_ready_read_data == 1'b1) begin
    			8'd0 : spi_read_data <= 32'hB7AADA2F;
    			8'd1 : spi_read_data <= max_count_0;
    			8'd2 : spi_read_data <= compare_val_0;
    			8'd3 : spi_read_data <= max_count_1;
    			8'd4 : spi_read_data <= compare_val_1;
    			8'd5 : spi_read_data <= max_count_2;
    			8'd6 : spi_read_data <= compare_val_2;
    			8'd7 : spi_read_data <= max_count_3;
    			8'd8 : spi_read_data <= compare_val_3;
    			8'd9 : spi_read_data <= max_count_4;
    			8'd10 : spi_read_data <= compare_val_4;
    			8'd11 : spi_read_data <= max_count_5;
    			8'd12 : spi_read_data <= compare_val_5;
    			8'd13 : spi_read_data <= max_count_6;
    			8'd14 : spi_read_data <= compare_val_6;
    			8'd15 : spi_read_data <= max_count_7;
    			8'd16 : spi_read_data <= compare_val_7;
    			default : spi_read_data <= 32'h00000000;
    		endcase
    	end
    end
    // PWM modules
    pwm_module pwm0(clk, max_count_0, compare_val_0, pwm_wire0);
    pwm_module pwm1(clk, max_count_1, compare_val_1, pwm_wire1);
    pwm_module pwm2(clk,...
  • SPI interface verilog HDL code
    sciencedude199011/02/2020 at 04:01 0 comments
    // The SPI interface
    // Supports loop-back for BER testing
    // 8 bit register address
    // 32 bit register values
    module spi_interface(
    	input wire clk,
    	input wire bar_ss,
    	input wire mosi,
    	input wire sck,
    	output wire miso,
    	output wire spi_ready_write_data,
    	output wire spi_ready_read_data,
    	output wire [7:0] spi_register_address,
    	output wire [31:0] spi_write_data,
    	input wire [31:0] spi_read_data
    // Observe the serial clock
    reg [2:0] sck_r;
    initial begin
    	sck_r <= 3'b000;
    end
    always @ (posedge clk) begin
    	sck_r <= {sck_r[1:0], sck};
    end
    // Detect the rising edge
    wire sck_risingedge = (sck_r[2:1]==2'b01);
    // Detect the falling edge
    wire sck_fallingedge = (sck_r[2:1]==2'b10);
    // Observe the mosi wire
    reg [1:0] mosi_r;
    	mosi_r <= {mosi_r[0], mosi};
    end
    // The mosi data
    wire mosi_data = mosi_r[1];
    // Observe bar_ss
    reg[2:0] bar_ss_r;
    initial begin
    	bar_ss_r <= 3'b111;
    end
    	bar_ss_r <= {bar_ss_r[1:0], bar_ss};
    end
    wire bar_ss_fallingedge = (bar_ss_r[2:1]==2'b10);
    // Observation of bar_ss
    wire bar_ss_observe = bar_ss_r[1];
    // Place to store input data
    // reg data_ready;
    reg [5:0] bit_count;
    reg [31:0] data_rx;
    reg [31:0] data_tx;
    initial begin
    	bit_count <= 6'd0;
    	data_tx <= 32'd0;
    end
    // Output is tristate, until bar_ss_observe becomes 0
    assign miso = (!bar_ss_observe) ? data_tx[31] : 1'bz;
    // Place to store the state variable
    // 0 Command arriving
    // 1 Read register, address arriving
    // 2 Read register, get the register value
    // 3 Read register, sending bits 31:0
    // 8 Write register, address arriving
    // 9 Write register, bits 30:0 arriving
    // 10 Write register, bit 31 is ready, write the register
    reg [3:0] spi_state;
    initial begin
    	spi_state <= 4'd0;
    end
    reg [7:0] spi_register_address_reg;
    reg [31:0] spi_write_data_reg;
    initial begin
    	spi_write_data_reg <= 32'd0;
    end
    // On the rising edge of the serial clock, data is ready for processing
    always @(posedge clk) begin
    	if (bar_ss_fallingedge == 1'b1) begin
    		// On the falling edge of bar_ss, clear bit count and set spi state
    		bit_count <= 6'd0;
    		spi_state <= 4'd0;
    	end else if ((bar_ss_observe == 1'b0) && (sck_risingedge == 1'b1)) begin
    		// If we have 7 bits, figure out the next state from the input bit
    		if (bit_count == 6'd7) begin
    			if ({data_rx[6:0], mosi_data} == 8'd0) begin
    				// the master is asking to read a register
    				spi_state <= 4'd1;
    			end else if ({data_rx[6:0], mosi_data} == 8'd1) begin
    				// the master is asking to write a register
    				spi_state <= 4'd8;
    			end
    		end
    		if (bit_count == 6'd15) begin
    			// If we are doing a SPI read, and are up to 15 bits total, prepare the register address, ready to send the register back
    			if (spi_state == 4'd1) begin
    				spi_register_address_reg <= {data_rx[6:0], mosi_data};
    				spi_state <= 4'd2;
    			end else if (spi_state == 4'd8) begin
    				// If we are doing a SPI write, and are up to 15 bits total, prepare the register address, ready to recieve the next 32 bits for the register
    				spi_state <= 4'd9;
    			end
    		end
    		// Have 31 bits for the register write, so get the mosi data to make 32 bits, set the state to 10
    		if ((bit_count == 6'd47) && (spi_state == 4'd9)) begin
    			spi_write_data_reg <= {data_rx[30:0], mosi_data};
    			spi_state <= 4'd10;
    		end
    		// Keep incrementing and sampling bits
    		bit_count <= bit_count + 6'd1;
    		data_rx <= {data_rx[30:0], mosi_data};
    	end else if ((bar_ss_observe == 1'b0) && (sck_fallingedge == 1'b1)) begin
    		// Transfer the register value to the local register, and change the state
    		if (spi_state == 4'd2) begin
    			data_tx <= spi_read_data;
    			spi_state <= 4'd3;
    		end else if (spi_state == 4'd10) begin
    			spi_state <= 4'd0;
    			bit_count <= 6'd0;
    		end else begin
    			// Near the end of register read, the next 8 bits will be a new command
    			if ((spi_state...
  • PWM module verilog HDL code
    sciencedude199011/02/2020 at 04:00 0 comments
    // PWM module
    // inputs
    //    clk - the clock signal, will use posedge
    //    max_count - the highest count value of the counter
    //    compare_val - the comparison value for the counter
    // outputs
    //    cmp - compares the internal counter to compare_val
    // note
    //    a counter that always counts up to max_count
    //    compares the counter to compare_val - if the counter is lower, output 1, otherwise output 0
    module pwm_module(
    input wire clk,
    input wire [31:0] max_count,
    input wire [31:0] compare_val,
    output wire cmp
    // Internal counter
    reg [31:0] cnt;
    // Set to 0 at start
    initial begin
    cnt <= 32'h00000000;
    end
    if (cnt < max_count) begin
    // If the counter is less than max_count, increment
    cnt <= cnt + 32'h00000001;
    end else begin
    // otherwise, set to 0
    cnt <= 0;
    end
    end
    // When count is less than the compare value, output 1, otherwise 0
    assign cmp = (cnt < compare_val) ? 1'b1 : 1'b0;
    endmodule
  • SDC file
    sciencedude199011/02/2020 at 03:59 0 comments
    # inform Quartus that the clk port brings a 50MHz clock into our design so
    # that timing closure on our design can be analyzed
    create_clock -name clk -period "50MHz" [get_ports clk]
    # inform Quartus that the LED output port has no critical timing requirements
    # it’s a single output port driving an LED, there are no timing relationships
    # that are critical for this
    set_false_path -from * -to [get_ports led1]
    set_false_path -from * -to [get_ports led2]
    set_false_path -from * -to [get_ports led3]
    set_false_path -from * -to [get_ports led4]
    set_false_path -from * -to [get_ports led5]
View all 4 project logs
