it's all in the title!
How did you know that I needed an automated heat shrink cutter? And when will you have the feed mechanism ready? ;-)
Hi Simon, using the aluminium extrusion, it would be a breeze to add a feed mechanism back or front :)
Greg Zumwalt
davedarko
wmacaluso
Ali
Yes, delete it Cancel
You are about to report the project "Servo actuated guillotine cutter. Cuts everything*", please tell us the reason.
