Lower leg part
A project log for K3lso Quadruped
K3lso is a quadruped robot similar to MIT mini cheetah and MIT Cheetah 3.
robin-frjdRobin Fröjd 01/02/2021 at 08:400 Comments
So I adjusted the length of the lower leg to 280mm. which makes upper / lower leg same length. 280/280mm. So revision two is more or less done.
I have also started to play around with some color choices (but haven't decided on covers yet).
The rubber details will be Pantone cool gray 10c.
