Filament AC voltage
A project log for VFD watch
bringing an old VFD back to life
ben-moBen Mo 12/24/2020 at 15:510 Comments
For filament we can use DC or AC voltage but AC has superiority over DC. If the filament is driven with a DC voltage there will be a voltage gradient across its length. This means the end of the display with the more positive filament voltage will have less of a differential to the anodes, and thus will be dimmer than the negative end of the filament due to the potential gradient effect.
http://insanity4004.blogspot.com/2017/03/p170-dh-vacuum-flourescent-display.html
https://www.qsl.net/m0ayf/VFD-Regen.html
to producing AC voltage i decided to use a microcontroller, in this case i choose an Attiny13 .
for achieving a 5v 60hz ac voltage i programmed two pins of Attiny13 as output and switching them on/off respectively with a 8 milliseconds delay.
void setup() {
  pinMode(0, OUTPUT);
  pinMode(1, OUTPUT);
void loop() {
  digitalWrite(0, HIGH);
  digitalWrite(1, LOW);
  delay(8);
  digitalWrite(0, LOW);
  digitalWrite(1, HIGH);
  delay(8);
