3mRespirator_centrifTubeFeeder_wCPAP_male_v1.gcode
gcode of the
gcode - 4.37 MB - 01/17/2021 at 03:09
Download
3mRespirator_centrifTubeFeeder_wCPAP_male_v1.stl
.stl Remix of the PAPR v1 by jwmelvin 3mRespirator_centrifTubeFeeder.stl with more enforcement of the connection sections and adding the CPAP male hose connection from the Full Face Snorkel T-Rex Blower PAPR (Positive Air Pressure Respirator) PPE adapter by k3nd0 VUB_Snorkel_remix_connector_V5.stl
Standard Tesselated Geometry - 587.68 kB - 01/17/2021 at 03:09
Download
3mRespirator_centrifTubeFeeder_wCPAP_male_v1.3mf
.3mf 3D Builder Remix of the PAPR v1 by jwmelvin 3mRespirator_centrifTubeFeeder.stl with more enforcement of the connection sections and adding the CPAP male hose connection from the Full Face Snorkel T-Rex Blower PAPR (Positive Air Pressure Respirator) PPE adapter by k3nd0 VUB_Snorkel_remix_connector_V5.stl
3mf - 140.94 kB - 01/17/2021 at 03:09
Download
3mRespiratorCentrifFilter_3M_needs_gasket_bottom_rev1.gcode
gcode of the.
gcode - 12.26 MB - 01/15/2021 at 02:48
Download
3mRespiratorCentrifFilter_3M_needs_gasket_bottom_rev1.stl
Remix of the PAPR v1 by jwmelvin and 40MM NATO (RD40x1/7) to 3M™ Filter Adapter by AgapeIngenium. I think this might be the most confident of the designs. Narrowed spacing for closer cartridge fit. Used Designspark Mechanical to create the base.
Standard Tesselated Geometry - 2.43 MB - 01/14/2021 at 09:30
Download
3mRespiratorCentrifFilter_3M_needs_gasket_bottom_rev1.3mf
3mf - 581.20 kB - 01/14/2021 at 09:30
Download
40MM_TO_3M_BAYONET_ADAPTER_INNER_SHELL_GEN5_upper_10mm.stl
The inner part with the lower portion split away. Not yet remixed from the 40MM NATO (RD40x1/7) to 3M™ Filter Adapter by AgapeIngenium.
Standard Tesselated Geometry - 8.70 MB - 01/14/2021 at 01:48
Download
40MM_TO_3M_BAYONET_ADAPTER_INNER_SHELL_GEN5_upper_10mm_0.1res_50infill_honeycomb.gcode
gcode of the.
gcode - 1.97 MB - 01/14/2021 at 01:47
Download
Not yet remixed from the PAPR v1 by jwmelvin
Standard Tesselated Geometry - 157.50 kB - 01/10/2021 at 08:53
Download
VUB_Snorkel_remix_connector_V5.gcode
gcode of.
gcode - 15.83 MB - 01/10/2021 at 08:24
Download
Standard Tesselated Geometry - 782.99 kB - 01/10/2021 at 08:23
Download
