ZoniX – Z80 Based System
ZoniX is my first Z80 based design with ECB and 40 pins expansion bus
Public Chat
ZoniX is my first Z80 based design with ECB and 40 pins expansion bus. This design aimed to be a retro game console (I hope), for now I will use this platform to learn the designing process and assembly language.
The ZoniX system will be spread across multiple ecb board to help with the development.
Wanted Features
- Z80 CPU ~ 10Mhz
- Use the Z84C90 KIO for Serial/Parallel Counter Timer to reduce chips count
- I/O ports for controllers and keyboard
- VGA output
- Memory map that allow for graphics expansion
- Add an external Bus for expansion in the future
- First 16k of the memory can be switch between ROM and RAM
- External ROM cartridge OR Compact Flash OR even better a SC card ?
ZoniX-Prototype-v0.4_GAL Logic.pdf
ZoniX Prototype v0.4 GAL22v10 schematic
Adobe Portable Document Format - 66.09 kB - 02/09/2021 at 23:32
Preview
Download
ZoniX-Prototype-v0.4_Schematic.pdf
ZoniX Prototype v0.4 schematic
Adobe Portable Document Format - 323.28 kB - 02/09/2021 at 23:32
Preview
Download
ZoniX-Prototype-v0.4_2021-02-09.pdf
ZoniX Prototype v0.4 layers
Adobe Portable Document Format - 1.80 MB - 02/09/2021 at 23:05
Preview
Download
ZoniX-Prototype-v0.4_2021-02-09.zip
ZoniX Prototype v0.4 Gerber file
x-zip-compressed - 313.85 kB - 02/09/2021 at 23:05
Download
  • 1 × Z84C008-PEC Z80 CPU
  • 1 × SST39SF040-70-4C-PHE Memory ICs / FLASH Memory
  • 1 × AS6C4008 Memory ICs / Static RAM (SRAM)
  • 1 × Z84C90-KIO Zilog KIO PLCC84
  • 2 × GAL22V10 Logic ICs / Programmable Logic: PLDs
View all 18 components
View all 3 project logs
