An inexpensive, easy-to-assemble, low power consumption Arduino Pro Mini data logger
ArduinoProMini_DataLogger_v1.0_Schematic_20230503.pdfArduino Pro Mini Data Logger v1.0 schematic diagramAdobe Portable Document Format - 32.53 kB - 05/03/2023 at 22:01 |
ArduinoProMini_DataLogger_v1.0_Gerbers_20230503.zipArduino Pro Mini Data Logger v1.0 Gerber filesx-zip-compressed - 41.61 kB - 05/03/2023 at 22:00 |
ArduinoProMini_DataLogger_v1.0_20230503.zipArduino Pro Mini Data Logger Shield v1.0 KiCad projectx-zip-compressed - 317.96 kB - 05/03/2023 at 21:59 |
DataLoggerShield_ArduinoProMini_BOM_02-14-2021.xlsxArduino Pro Mini Data Logger v1.0 bill of materialssheet - 12.71 kB - 02/14/2021 at 18:42 |
I received the Datalogger v1.0 boards from OSH Park last night. Soldering took less than 30 minutes for this first board. Everything is operational. This is very encouraging for my first PCB design.
The data logging script sequence:
Then the user can pull the .csv data file from the SD card as needed and plot the data.
I ordered qty 3 of the first revision of the data logger shield from OSH Park last night. PCBs should arrive in the next couple of weeks.
Header components are on order from Digi-Key.
Looking like the total material cost will be around $35 per shield.
May I get the gerber files for this PCB? I am doing a datalogger to record when clouds form in huge underground cave rooms in China.
Thanks!
