Battery replacement
A project log for Cheap RC Car : maintenance
What can break on such a piece of junk and how to fix it.
Christoph TackChristoph Tack 03/08/2021 at 20:030 Comments
The car is supposed to work with 6 AA-cells in series.  Only rechargeable cells are an option here.
NiMH
Li-ION
Setup 1
  1. Using a LiitoKala NCR18650B
  2. Charger : TP4056
  3. Protector : the single 8205A doesn't allow enough current.  So the over-current protection had to be bypassed.  This also disables under-voltage protection.  When someone forgets to turn off the car, the battery will be drained to death (as has happened already)
  4. Boost circuit to boot the Li-ION cell voltage to 9V using XT1208 (advertised differently).  This seems to work well.
Setup 2
Using the IOT-supply.
