High Flow Oxygen Concentrator 15 LPM at 90%+ Concentrated o2 https://oxikit.com
Portable Network Graphics (PNG) - 43.01 kB - 03/22/2021 at 02:53 |
f3d - 7.33 MB - 03/20/2021 at 09:12 |
Adobe Portable Document Format - 880.71 kB - 03/20/2021 at 09:12 |
Adobe Portable Document Format - 1.02 MB - 03/20/2021 at 09:12 |
Adobe Portable Document Format - 802.42 kB - 03/20/2021 at 09:12 |
I looked at the compressor and it appears to be a 120v 60hz unit. India and some of it's neighbors are 220v 50hz... I am not sure that it is a scroll.
It's exciting to work on this project, I am adding few remote capabilities to the system to monitor and control certain parameters and introduce some automation into the sytem
It is a diaphragm compressor. They are oil less. It is like a 2 cylinder engine but instead of pistons it has a rubber disc that is used to pump the air. That is also why you don't need oil, because the rubber disc is just pumped up and down instead of moving.
Wow, I didn't expect so much enrichment at such a high flow! What kind of compressor is that? I'd imagine it would need to be oil-less -- perhaps a scroll compressor?
Hi Dan!
you may have look at the provided files, all the compressor spec are mentioned
heyaa
