Universal-Internet-Connected-Remote-Control
This IoT project that allows its users to send IR signals from any computer within a network.
IoT project that allows its users to send IR signals from any computer within a network. For that purpose, an ESP8266-enabled development board is connected to an IR sender module, and the finished device hosts a website that allows users to send out codes. The device can be useful, for example, to remote-control several devices from within a network without having to replace the existing electronic equipment with connected items. project made by R.V.S Aditya for more follow me on instagram and github
prototype
Schematic
Universal Internet Connected Remote Control co.docx
document - 382.25 kB - 04/02/2021 at 08:08
Download
Universal Internet Connected Remote Control.docx
document - 22.10 kB - 04/02/2021 at 07:59
Download
  • 1 × 940nm IR LED
  • 1 × ESP8266 based development board
  • 1 × 68 Ohm resistor
  • 1 × NPN transistor
  • 1 × 330 Ohm resistor
View all 10 components
  • Arduino.ino
    HackAtech Industries04/02/2021 at 07:56 0 comments
    //code of Universal Internet Connected Remote Control
    // idea form maker.io
    //made by RVS Aditya From HackAtech Industries
    #include <IRremoteESP8266.h>
    #include <IRsend.h>
    #include <ESP8266WiFi.h>
    #define LED_PIN 5
    #define STORAGE_SIZE 5
    const char* ssid = "YOUR_NETWORK_NAME";
    const char* pass = "NETWORK_PASSWORD";
    WiFiServer server(80);
    IRsend sender(LED_PIN);
    long codes[STORAGE_SIZE] = {0x00123,0x02,0xAB,0x0F,0x0};
    bool stored[STORAGE_SIZE] = {true,false,false,false,false};
    int protocols[STORAGE_SIZE] = {0,1,1,0,1};
    // Function Prototypes
    int containsValidIndex(String);
    String findParameterValue(String, String);
    void setup()
      Serial.begin(9600);
      while(!Serial)
    	delay(50);
      sender.begin();
      Serial.println("");
      Serial.print("Connecting to ");
      Serial.print(ssid);
      WiFi.begin(ssid, pass);
      while(WiFi.status() != WL_CONNECTED)
    	Serial.print(".");
    	delay(500);
      Serial.println("Done!");
      Serial.println("Starting server...");
      server.begin();
      Serial.print("Server started with address ");
      Serial.print("http://");
      Serial.print(WiFi.localIP());
      Serial.println("/");
    void loop()
      // Check for incoming connections
      WiFiClient c = server.available();
      if(c)
    	while(!c.available())
      	delay(10);
    	// Read the first line of the HTTP request
    	// It contains something similar to the following line:
    	// METHOD /requested_url HTTP_VERSION
    	// for example:
    	// GET /send?value=0x0085&protocol=NEC HTTP/1.1
    	// However, for the sake of simplicity this device only accepts
    	// GET requests as they can be sent with any web browser.
    	// Updating values this way is not the 'correct' way according to
    	// the HTTP standard but it makes using the device easier.
    	String request = c.readStringUntil('\r');
    	c.flush();
    	int error = 0;
    	int value = request.indexOf("value=");
    	int protocol = request.indexOf("protocol=");
    	int index = request.indexOf("index=");
    	int snd = request.indexOf("/send");
    	int str = request.indexOf("/store");
    	int del = request.indexOf("/delete");
    	Serial.println(request);
    	// The following few if/else-statements parse the incoming request
    	// and then execute the action that the user requested.
    	// The user requested the send page and did not include /store or /delete in their request
    	if (snd != -1 && str == -1 && del == -1)
      	// The user requested the send page and included a value for the index
      	if(index != -1)
        	// Check if the supplied index is valid (i.e. at least zero and less than STORAGE_SIZE)
        	// And check if the values array contains an entry at the requested position
        	// First, get the value of the parameter as a string
        	String index_string = findParameterValue(request, "index");
        	// Next, convert it to an integer and check whether the value is valid
        	int i = containsValidIndex(index_string);
        	if(i > -1 && stored[i])
          	// The parameter was valid. Repeat the stored value!
          	// Make sure to verify the bit length for your remotes!
          	// I used 32 and 14 in this program, but yours might vary
          	if(protocols[i] == 0)
            	sender.sendNEC(codes[i], 32);
          	else
            	sender.sendRC5(codes[i], 14);
          	Serial.print("Repeat the value stored at position ");
          	Serial.println(i);
      	// The user supplied the wrong parameters for this request.
      	else
        	error = 1;
        	Serial.print("Unknown request: ");
    	// The user requested the /store page and the request didn't include
    	// the /send or /delete page
    	else if(str != -1 && snd == -1 && del == -1)
      	// (Either of the three parameters is missing)
      	if(index == -1 || protocol == -1 || value == -1)
        	error = 1;
        	Serial.print("BAD REQUEST. Missing field: ");
      	else
        	String p = findParameterValue(request, "protocol");
        	String v = findParameterValue(request, "value");
        	int i = containsValidIndex(findParameterValue(request, "index"));
        	if(i > -1)
View project log
