IoT Weather Sculpture
A freeform circuit that shows the weather
I am trying to learn how to use those Arduino modules that connect to the internet. As a starter project, I am making a small sculpture to display the weather.
Freeform circuit weather display.
weather_sculpture_export.ino
code for the sculpture
ino - 6.30 kB - 04/15/2021 at 20:30
Download
Graphics Interchange Format - 12.71 MB - 04/16/2021 at 01:01
Preview
JPEG Image - 1.43 MB - 04/16/2021 at 01:06
Preview
JPEG Image - 1.70 MB - 04/16/2021 at 01:06
Preview
JPEG Image - 1.37 MB - 04/16/2021 at 01:06
Preview
View all 12 files
  • 1 × NodeMCU A WiFi module
  • 7 × 1K resistor (or similar value)
  • 30 × LEDs (just an estimate of the number)
  • 1 × Copper wire 18-20 gauge
  • Built It!
    A-A-W04/15/2021 at 20:48 0 comments
    I put the LEDs in the mold and soldered the ground together, then added positive rails for each color LED. Then I took it out of the mold and soldered it to the circuit board.
    I also had to fix a couple of problems with my code (the pinout for the NodeMCU is confusing...)
    Last, I painted over one of the on-board LEDs so that it wouldn't be so bright and distracting.
    This was a fun little project that helped me to learn about how to use WiFi with Arduino boards.
    Hope you liked my idea!
  • Internet!
    A-A-W04/10/2021 at 11:58 0 comments
    I set up an Adafruit IO feed and connected it to Weather Underground through IFTTT to send the weather every morning at 6:00 AM.
    I connected the circuit to the internet and tested it with three LEDs to show basic weather (white=cloudy, yellow=sunny, blue=showers/rainy). I also 3D printed a mold/jig to hold the LEDs while soldering.
View all 2 project logs
Maakbaas wrote 04/16/2021 at 19:48 point
Very creative! Nicely done.
