MQTT ioModul
wired Ethernet IO module that is based on MQTT and has 16 digital inputs and 16 digital outputs
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
Starting from
$41.00
xmmqtt has 4 orders / 0reviews
Ships from Germany
We have been looking for a wired Ethernet IO module that is based on MQTT and has many digital inputs and outputs for a long time.
Since we couldn't find anything that met our expectations, we designed such a module with 16 inputs and 16 outputs based on a powerful ESP32 microcontroller.
The wall cabinets picture shows the prototype of the module, 3 pieces in the middle on the right side. The other pictures show the final module.
DETAILS
- 16 digital inputs, 12-24V based, galvanically isolated
- 16 digital outputs, 12-24V based, galvanically isolated
- Ethernet RJ45 interface with MQTT protocol is used to set an output or inform about
input changes
- Status inputs and outputs as well as status of modul is signaled by LED
- Easy parameter configuration (IP addresses, debounce time, …)
- No specialized outputs, so that voltages up to 230V can switched via coupling relay
More informations see: xmmqtt.de
