Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Courses Tutorials Events Hackerspaces Profiles Hackaday.com Tindie Marketplace
Sign up Log in
TinyNeoController
Control almost any number of NeoPixels with an ATtiny13A and an IR Remote
Stefan WagnerStefan Wagner
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
200 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 0
  • Instructions 0
  • Discussion 0
View Gallery
216
0
200
8
Team (1)
  • Stefan WagnerStefan Wagner
Join this project's team
  • Project Files (Github)
  • Project Files (EasyEDA)
Software
completed project
avr attiny attiny13 ATtiny13a IR REMOTE arduino project diy pcb Neopixel led
This project was created on 05/13/2021 and last updated a year ago.
Description
An ATtiny13 is more than sufficient to control almost any number of NeoPixels via an IR remote. The NeoController was originally developed as a tester for 800kHz NeoPixel strips. Since there was still so much flash left in the ATtiny13, an IR receiver was integrated so that some parameters can be controlled with an IR remote control. In this way, it is also suitable as a simple and cheap remote-controlled control unit for NeoPixels. Due to its small size (21.6mm x 11.4mm), it can be soldered directly to the LED strip without any problems. The power supply via a USB-C connection enables currents of up to 3A. There is still more than a third of the flash memory left for additional ideas.
Details
Log In/Sign up to comment
Sign up with Github
OR
Remote Control Animatronic Plush Shark
Project Owner Contributor
OPShark
Dan SheadelDan Sheadel
Generic Bus Shutter Controller for 3 brands of switch
Web Enabled Shutter v2
Florian CliquetFlorian Cliquet
It's now implemented PS2 remote control, aircraft model remote control, and PPM receiver manually controlled.
How to Make a Lunar Rover From Zero?
RT-Thread IoT OSRT-Thread IoT OS
Very simple remote switch, controllable by any infrared remote control
IR2IO
rootfrogsMakesrootfrogsMakes
Going up?
© 2022 Hackaday
Yes, delete it Cancel
You are about to report the project "TinyNeoController", please tell us the reason.
Send message
Remove Member
