KT6368A is a dual-mode pure data chip that supports Bluetooth 5.1 version BLE and 2.1 version SPP function. The highlight of the chip is its ultra-small size and ultra-low price. And simple transparent transmission and serial AT control function. Greatly reduce the difficulty and cost of developing embedded Bluetooth in other products. KT6368A supports connecting to mobile phones for two-way data interaction, commonly known as "Bluetooth Transparent Transmission". Through the UART interface, it supports common AT commands, such as: setting name, setting address, setting baud rate and so on.
Q: can this chip transmit bluetooth audio signal to be received directly by a bluetooth earphones?
