Morse Blinky
Satellite dish free-form circuit sculpture that blinks an LED in Morse code
First attempt at a free-form circuit sculpture. I had an ATtiny24a lying around and set up a simple circuit, powering the ATtiny from a 3V coin cell and driving an LED through one of the digital pins. The LED blinks out a message in Morse code, the firmware is stored in a Github repository. I used an Arduino Uno running the ArduinoISP sketch to program the ATtiny.
For the sculpture part I wanted something that looked like it was meant to transmit. I went with a satellite dish design using 22 gauge brass wire to build the structure. The dish form was built first and then I precariously soldered it to the base. Because the circuit was so simple I connected it in afterwards.
morse-blinky.pdf
Schematic
Adobe Portable Document Format - 16.20 kB - 06/27/2021 at 21:18
Preview
  • 1 × ATtiny24a, 14 DIP Microprocessors, Microcontrollers, DSPs / ARM, RISC-Based Microcontrollers
  • 1 × IN5817 Diode Schottky 20 V 1A Through Hole DO-204AL (DO-41)
  • 1 × 0.1u ceramic capacitor Ceramic capacitor
  • 1 × 56ohm resistor Resistor, axial
  • 1 × LTL1CHKSKNN LEDs and Accessories / Light Emitting Diodes (LEDs)
View all 6 components
