1Supplies
23D Printing
- 3D Print the given 3D Models.
- Note: If you don't find the same Push Buttons as mine please design your own Keypad.
- Once the print is complete insert the pushbuttons and fix them with some quick glue.
3Circuit Connection
- Make all the connections as shown in the schematic diagram.
- Put the 3D-printed keys on top of the buttons using fast glue.
- fix the RPi Pico using some screws.
4Code Step 1
- Download Circuitpython File
- Hold the Bootsel button of the pico and plug it to your PC.
- Copy-paste the file into the Raspberry Pi Pico directory.
- The board will reconnect automatically.
5Code Step 2
- Download the GitHub repository
- Extract the file.
- Copy the adafruit_hid file and paste it in pico directory -> lib (in lib folder).
6Code Step 3
- Download the Thony and install it (Do watch some tutorials if you are a RPi Pico beginner).
- Open the Pico directory and open the code.
- Now go to Tools -> Options -> interpreter -> and select Circuitpython(generic).
- Copy-paste the given code into the editor and save it.
import time import digitalio import board import usb_hid from adafruit_hid.keyboard import Keyboard from adafruit_hid.keycode import Keycode from adafruit_hid.mouse import Mouse btn1_pin=board.GP2 btn2_pin=board.GP3 btn3_pin=board.GP4 btn4_pin=board.GP6 btn5_pin=board.GP7 btn6_pin=board.GP8 btn7_pin=board.GP10 btn8_pin=board.GP11 btn9_pin=board.GP12 keyboard = Keyboard(usb_hid.devices) mouse = Mouse(usb_hid.devices) btn1 = digitalio.DigitalInOut(btn1_pin) btn2 = digitalio.DigitalInOut(btn2_pin) btn3 = digitalio.DigitalInOut(btn3_pin) btn4 = digitalio.DigitalInOut(btn4_pin) btn5 = digitalio.DigitalInOut(btn5_pin) btn6 = digitalio.DigitalInOut(btn6_pin) btn7 = digitalio.DigitalInOut(btn7_pin) btn8 = digitalio.DigitalInOut(btn8_pin) btn9 = digitalio.DigitalInOut(btn9_pin) btn1.direction = digitalio.Direction.INPUT btn2.direction = digitalio.Direction.INPUT btn3.direction = digitalio.Direction.INPUT btn4.direction = digitalio.Direction.INPUT btn5.direction = digitalio.Direction.INPUT btn6.direction = digitalio.Direction.INPUT btn7.direction = digitalio.Direction.INPUT btn8.direction = digitalio.Direction.INPUT btn9.direction = digitalio.Direction.INPUT btn1.pull = digitalio.Pull.DOWN btn2.pull = digitalio.Pull.DOWN btn3.pull = digitalio.Pull.DOWN btn4.pull = digitalio.Pull.DOWN btn5.pull = digitalio.Pull.DOWN btn6.pull = digitalio.Pull.DOWN btn7.pull = digitalio.Pull.DOWN btn8.pull = digitalio.Pull.DOWN btn9.pull = digitalio.Pull.DOWN while True: if btn1.value: print("Button 1 pressed") keyboard.press(Keycode.LEFT_SHIFT,Keycode.LEFT_ALT, Keycode.UP_ARROW) time.sleep(0.1) keyboard.release(Keycode.LEFT_SHIFT,Keycode.LEFT_ALT, Keycode.UP_ARROW) if btn2.value: print("Button 2 pressed") keyboard.press(Keycode.LEFT_CONTROL, Keycode.FORWARD_SLASH) time.sleep(0.1) keyboard.release(Keycode.LEFT_CONTROL, Keycode.FORWARD_SLASH) if btn3.value: print("Button 3 pressed") keyboard.press(Keycode.LEFT_ALT, Keycode.UP_ARROW) time.sleep(0.1) keyboard.release(Keycode.LEFT_ALT, Keycode.UP_ARROW) if btn4.value: print("Button 4 pressed") keyboard.press(Keycode.LEFT_SHIFT,Keycode.LEFT_ALT, Keycode.DOWN_ARROW) time.sleep(0.1) keyboard.release(Keycode.LEFT_SHIFT,Keycode.LEFT_ALT, Keycode.DOWN_ARROW) if btn5.value: print("Button 5 pressed") keyboard.press(Keycode.LEFT_CONTROL, Keycode.B) time.sleep(0.1) keyboard.release(Keycode.LEFT_CONTROL, Keycode.B) if btn6.value: print("Button 6 pressed") keyboard.press(Keycode.LEFT_ALT, Keycode.DOWN_ARROW) time.sleep(0.1) keyboard.release(Keycode.LEFT_ALT, Keycode.DOWN_ARROW) if btn7.value: print("Button 7 pressed") keyboard.press(Keycode.WINDOWS, Keycode.PRINT_SCREEN) time.sleep(0.1) keyboard.release(Keycode.WINDOWS, Keycode.PRINT_SCREEN) if btn8.value: print("Button 8 pressed") keyboard.press(Keycode.LEFT_ALT, Keycode.F4) time.sleep(0.1) keyboard.release(Keycode.LEFT_ALT, Keycode.F4) if btn9.value: print("Button 9 pressed") keyboard.press(Keycode.WINDOWS, Keycode.G) time.sleep(0.1) keyboard.release(Keycode.WINDOWS, Keycode.G) time.sleep(0.3)
7Key Codes
""" `adafruit_hid.keycode.Keycode` ==================================================== * Author(s): Scott Shawcroft, Dan Halbert """ """USB HID Keycode constants. This list is modeled after the names for USB keycodes defined in https://usb.org/sites/default/files/hut1_21_0.pdf... This list does not include every single code, but does include all the keys on a regular PC or Mac keyboard. Remember that keycodes are the names for key *positions* on a US keyboard, and may not correspond to the character that you mean to send if you want to emulate non-US keyboard. For instance, on a French keyboard (AZERTY instead of QWERTY), the keycode for 'q' is used to indicate an 'a'. Likewise, 'y' represents 'z' on a German keyboard. This is historical: the idea was that the keycaps could be changed without changing the keycodes sent, so that different firmware was not needed for different variations of a keyboard. """ A """``a`` and ``A``""" B """``b`` and ``B``""" C """``c`` and ``C``""" D """``d`` and ``D``""" E """``e`` and ``E``""" F """``f`` and ``F``""" G """``g`` and ``G``""" H """``h`` and ``H``""" I """``i`` and ``I``""" J """``j`` and ``J``""" K """``k`` and ``K``""" L """``l`` and ``L``""" M """``m`` and ``M``""" N """``n`` and ``N``""" O """``o`` and ``O``""" P """``p`` and ``P``""" Q """``q`` and ``Q``""" R """``r`` and ``R``""" S """``s`` and ``S``""" T """``t`` and ``T``""" U """``u`` and ``U``""" V """``v`` and ``V``""" W """``w`` and ``W``""" X """``x`` and ``X``""" Y """``y`` and ``Y``""" Z """``z`` and ``Z``""" ONE """``1`` and ``!``""" TWO """``2`` and ``@``""" THREE """``3`` and ``#``""" FOUR """``4`` and ```""" FIVE """``5`` and ``%``""" SIX """``6`` and ``^``""" SEVEN """``7`` and ``&``""" EIGHT """``8`` and ``*``""" NINE """``9`` and ``(``""" ZERO """``0`` and ``)``""" ENTER """Enter (Return)""" RETURN """Alias for ``ENTER``""" ESCAPE """Escape""" BACKSPACE """Delete backward (Backspace)""" TAB """Tab and Backtab""" SPACEBAR """Spacebar""" SPACE """Alias for SPACEBAR""" MINUS """``-` and ``_``""" EQUALS """``=` and ``+``""" LEFT_BRACKET """``[`` and ``{``""" RIGHT_BRACKET """``]`` and ``}``""" BACKSLASH """``\`` and ``|``""" POUND """``#`` and ``~`` (Non-US keyboard)""" SEMICOLON """``;`` and ``:``""" QUOTE """``'`` and ``"``""" GRAVE_ACCENT """:literal:`\`` and ``~``""" COMMA """``,`` and ``<``""" PERIOD """``.`` and ``>``""" FORWARD_SLASH """``/`` and ``?``""" CAPS_LOCK """Caps Lock""" F1 """Function key F1""" F2 """Function key F2""" F3 """Function key F3""" F4 """Function key F4""" F5 """Function key F5""" F6 """Function key F6""" F7 """Function key F7""" F8 """Function key F8""" F9 """Function key F9""" F10 """Function key F10""" F11 """Function key F11""" F12 """Function key F12""" PRINT_SCREEN """Print Screen (SysRq)""" SCROLL_LOCK """Scroll Lock""" PAUSE """Pause (Break)""" INSERT """Insert""" HOME """Home (often moves to beginning of line)""" PAGE_UP """Go back one page""" DELETE """Delete forward""" END """End (often moves to end of line)""" PAGE_DOWN """Go forward one page""" RIGHT_ARROW """Move the cursor right""" LEFT_ARROW """Move the cursor left""" DOWN_ARROW """Move the cursor down""" UP_ARROW """Move the cursor up""" KEYPAD_NUMLOCK """Num Lock (Clear on Mac)""" KEYPAD_FORWARD_SLASH """Keypad ``/``""" KEYPAD_ASTERISK """Keypad ``*``""" KEYPAD_MINUS """Keyapd ``-``""" KEYPAD_PLUS """Keypad ``+``""" KEYPAD_ENTER """Keypad Enter""" KEYPAD_ONE """Keypad ``1`` and End""" KEYPAD_TWO """Keypad ``2`` and Down Arrow""" KEYPAD_THREE """Keypad ``3`` and PgDn""" KEYPAD_FOUR """Keypad ``4`` and Left Arrow""" KEYPAD_FIVE """Keypad ``5``""" KEYPAD_SIX """Keypad ``6`` and Right Arrow""" KEYPAD_SEVEN """Keypad ``7`` and Home""" KEYPAD_EIGHT """Keypad ``8`` and Up Arrow""" KEYPAD_NINE """Keypad ``9`` and PgUp""" KEYPAD_ZERO """Keypad ``0`` and Ins""" KEYPAD_PERIOD """Keypad ``.`` and Del""" KEYPAD_BACKSLASH """Keypad ``\\`` and ``|`` (Non-US)""" APPLICATION """Application: also known as the Menu key (Windows)""" POWER """Power (Mac)""" KEYPAD_EQUALS """Keypad ``=`` (Mac)""" F13 """Function key F13 (Mac)""" F14 """Function key F14 (Mac)""" F15 """Function key F15 (Mac)""" F16 """Function key F16 (Mac)""" F17 """Function key F17 (Mac)""" F18 """Function key F18 (Mac)""" F19 """Function key F19 (Mac)""" LEFT_CONTROL """Control modifier left of the spacebar""" CONTROL = LEFT_CONTROL """Alias for LEFT_CONTROL""" LEFT_SHIFT """Shift modifier left of the spacebar""" SHIFT = LEFT_SHIFT """Alias for LEFT_SHIFT""" LEFT_ALT """Alt modifier left of the spacebar""" ALT = LEFT_ALT """Alias for LEFT_ALT; Alt is also known as Option (Mac)""" OPTION = ALT """Labeled as Option on some Mac keyboards""" LEFT_GUI """GUI modifier left of the spacebar""" GUI = LEFT_GUI """Alias for LEFT_GUI; GUI is also known as the Windows key, Command (Mac), or Meta""" WINDOWS """Labeled with a Windows logo on Windows keyboards""" COMMAND """Labeled as Command on Mac keyboards, with a clover glyph""" RIGHT_CONTROL """Control modifier right of the spacebar""" RIGHT_SHIFT """Shift modifier right of the spacebar""" RIGHT_ALT """Alt modifier right of the spacebar""" RIGHT_GUI """GUI modifier right of the spacebar"""
- As you can see in the above code paragraph we have lines keyboard.press(Keycode.LEFT_SHIFT,Keycode.LEFT_ALT, Keycode.UP_ARROW) and keyboard.release(Keycode.LEFT_SHIFT,Keycode.LEFT_ALT, Keycode.UP_ARROW)
- The keyboard.press is to perform the key action and keyboard.release is for releasing the key action.
- If we don't release the key then the key action will perform again and again unless we shut down the system so always remember to release the key.
- you can add your own shortcuts by referring to the Keycodes.
- For example, if I want to make a key for copy the in the keyboard.press and keyboard.release I have to add
(Keycode.LEFT_CONTROL, Keycode.C)
- The code should look something like this
if btn5.value: print("Button 5 pressed") keyboard.press(Keycode.LEFT_CONTROL, Keycode.C) time.sleep(0.1) keyboard.release(Keycode.LEFT_CONTROL, Keycode.C)
- Note: Ignore the shell error, just edit the code and save, the keypad will run without any issue.
8Final Step
- Put the 3D printed base using screws or glue.
