Hackaday.io Hackaday.io
Recently Updated Most Likes Newest Project Lists
Sign up Log in
pooterbooter
Mount and boot iso images over network - pxe iPXE DI LTSP
gintaras-valatkaGintaras Valatka
Following Follow project
Liked Like project
Become a Hackaday.io member
Sign up with Github
Sign up with Twitter
OR
Forgot your password?
Just one more thing
Pick an awesome username
hackaday.io/
Pick a few interests
Choose more interests.
OK, I'm done! Skip
Join this project
0 comments
1 followers
  • Description
  • Details
  • Files 0
  • Components 0
  • Logs 2
    • View all
  • Instructions 0
  • Discussion 0
  • 2021 Hackaday Prize
View Gallery
110
0
1
0
Team (1)
  • gintaras-valatkaGintaras Valatka
Join this project's team
  • pooterbooter
Software
ongoing project
PXE 2021hackadayprize ipxe ltsp di remote boot
This project is submitted for
  • Challenge 2: Refresh Work-From-Home Life
This project was created on 07/13/2021 and last updated 2 years ago.
Description
If you don't feel like dd'ing iso images into usb keys, then maybe read on..
Download iso images and start the admin panel. The script will find *.iso files and will let you mount it. It will also update boot menu
Project Logs
Collapse
  • v0.0.2 iPXE apt-cacher-ng di-netboot-assistant
    Gintaras Valatka • 07/23/2021 at 21:46 • 0 comments
    If you have more than one Raspberry Pi or Debian/Ubuntu, install auto-apt-proxy on every machine, which auto finds and connects to installed apt-cacher-ng server. If you reinstall or download packages on multiple hosts this will save you bandwidth and speed up installations.
    GUI to download Debian/Ubuntu - this must be the easiest way to install! No need to download full or minimal netinst iso images, no need to run md5/sha sum checks. Only the first install is slower, following installs will be lightning if using apt-cacher-ng
    Define locale/packages in admin/config.php autoinstall with preseed.cnf soon
    Can Live boot Debian and Ubuntu via NFS, can boot windows 10 setup
    /etc/di-netboot-assistant/di-sources.list could be updated with more architectures like http://deb.debian.org/debian/dists/testing/main/
    What would happen if Raspberry Pi4 was pxe booted? (I don't have one yet) http://deb.debian.org/debian/dists/testing/main/installer-armhf/current/images/device-tree/
  • v0.0.1 pxe only
    Gintaras Valatka • 07/13/2021 at 23:14 • 0 comments
    v0.0.1 is pxe only
    https://github.com/soholt/pooterbooter/releases/tag/v0.0.1
    Archlinux boots in 4min from Raspberry Pi1, ubuntu slow to dowload via 100Mb network
    It boots archlinux, clonezilla (and debian/ubuntu live (slow, (4Gb+ ram)) instructions: https://github.com/soholt/pooterbooter/blob/v0.0.1/README.md
    wait for v0.02)
View all 2 project logs
Log In/Sign up to comment
Sign up with Github
OR
How to turn your Raspberry Pi into an all-in-one retro gaming console
Project Owner Contributor
Retropie: Full guide for Raspberry Pi
dmitryDmitry
Use your Raspberry Pi to "convert" your WiFi connection to wired. Use your old router as access point with Ad-Blocking.
Raspberry Pi route WiFi through Ethernet
dimitris-matsoukasDimitris Matsoukas
Step-by-step instructions on running Remote Desktop on Raspberry Pi with tips and tricks
3 Ways to Run a Remote Desktop on Raspberry Pi
dmitryDmitry
ExaGear Desktop brief feature description guide
ExaGear Desktop virtual machine for Raspberry Pi
dmitryDmitry
Going up?
© 2023 Hackaday
Yes, delete it Cancel
You are about to report the project "pooterbooter", please tell us the reason.
Send message
Remove Member
