Wi-Fi Weather Station System
Using Wemos D1 minis, I2C temperature sensors, 7-segment displays, neopixels, buttons, & project boxes, Tasmota, MicroPython, and MQTT.
This Wi-Fi-area temperature sensing & reporting project uses Wemos D1 mini boards, I2C temperature sensors, 7-segment displays, neopixels, buttons, and project boxes. Tasmota is used on sensor boxes, MicroPython on display boxes, and the Mosquitto MQTT server on hardware of your choice, e.g. a Raspberry Pi.
The BOM for each sensor/display box is approximately $8 (from Amazon.com), not including 5V/USB power adapters or cables. Any number of sensor & display boxes may be mixed-and-matched, with display box buttons controlling temp/humidity display and sensor group display. This specific project is configured for 4 sensor boxes in 2 indoor/outdoor groups and one display box.
Using Tasmota on sensor boxes allows them to be easily accessed from Home Assistant and, from there, smartphone apps plus any device with a local network connection & a web browser.
Tom wrote 08/05/2022 at 14:31 point
This is not a project....it's more like click-bait.  it should be deleted.
