This code for a WS2818B SPI controller using the ATtiny85. It is loosely based on the ATtiny10 Neopixel controller by Wayne Holder.
The controller requires three pins on the ATtiny85. The pin assignments can be changed in the defines, but the following shows the default layout. PB5 (Pin 1) should probably be connected to Vcc through a resistor in the 10k- to 30k-ohm range.
Expected Connection Diagram
+====+ Vcc -> PB5 |* | Vcc NC <- PB3 | | PB2 <- CLK LEDs -- PB4 | | PB1 -- NC GND | | PB0 <- MOSI +====+
Direct Dependencies
- PlatformIO is used to manage the build environment.
Contribution guidelines
- Use GitFlow
