Work Started On The TCD1304 Proto-board/ADC (AD7667) Proto-board
A project log for DAV5 V3.01 Raman Spectrometer
The only thing worth doing, is the thing worth doing right!
david-h-haffner-srDavid H Haffner Sr 03/10/2017 at 00:370 Comments
These are the major components soldered in place on the TCD1304AP proto board. This is the 1st board facing the 2nd focal mirror.
This is a closeup view showing the MAX232EIN and the placement of the AD8021A op-amp.
This is the ADC (AD7667AP) placed on a 48 pin Schmartboard. This will be positioned on a 2nd proto board behind the 1st board with a 6 pin dual row terminal for the TCD1304 which will interface separately on the MCU and the rest of the terminating pins on the ADC will have their separate terminal at the MCU.
