1Print and prepare the case
To prepare the build, begin with 3d-printing the case.
This case (*.stl-file) is part of the driver-pack of the screen/esp32 combi from Dustin Watts' github repro.
https://github.com/DustinWatts/FreeTouchDeck/tree/master/case/ESP32_TFT_Combiner_CaseJust place all sensors so the breakout-boards don't interfere with each other. A few sensors are just pressed into the cutouts and fit well. Keep space for the LiPo-battery.
The AS7265 ist placed at the end of a short, small pipe, with fits into the drilled hole.
2Wiring
Screw the screen into the case and connect all sensors.
**the VL53L3cx is missing two connections, and I'll update the wiring soon**
3Code
Upload code & 'voila'!
ha-ha! nice joke =) (about P3)
I did provide the pre-compiled code. (:
