Interfaces
A project log for Sol-20 Reproduction
I am making a full sized Sol-20 reproduction, the first fully assembled microcomputer with a built-in keyboard and television output.
Michael GardiMichael Gardi 11/22/2021 at 02:040 Comments
Here is a photo of the back of an original Sol-20.
You can see that the whole left side is taken up with power supply components: power button, fan, fuse, and  power cord connection. Since my reproduction does not require any of these I chose to focus on and highlight the interface section in the lower right part of the rear panel.
So I designed and printed my own "interface" panel and dug through my parts box for the components to populate it.
I then attached the interfaces panel to the rear panel with glue and braces.
Then I added the connection hardware. Here is what the back of my reproduction look like.
Understand at this point these ports are mostly for show. I already have a "virtual" cassette so I'm unlikely to implement a physical one. I do plan to get the serial interface working, but since I have nothing with a parallel interface to connect to, I probably won't wire that one up. While I don't plan to support real Sol-20 personality modules, I do have an idea that I might simulate a personality module with perhaps RFID tags to have the Sol-20 reproduction load different software modules on system startup.  Right now the personality module slot is just a simple hole.
