Ameba Arduino: Scan Available WiFi Hotspots
This example uses Ameba to scan available WiFi hotspots in the surroundings, and prints the SSID, encryption type, etc.
0 followers
In this example, we use Ameba to scan available WiFi hotspots in the surroundings, and prints the SSID, encryption type, signal strength information of each detected hotspot.
For more information:
  • 1 × AmebaD [RTL8722DM / RTL8722CSM / RTL8722DM MINI]
  • 1 × Antenna
  • 1
    Setup
    First, make sure the correct Ameba development board is selected in Arduino IDE: “Tools” -> “Board” ->
    Open the “ScanNetworks” example in “File” -> “Examples” -> “AmebaWiFi” -> “ScanNetworks”:
    wifi-1-2
  • 2
    Upload and execution
    Then upload the sample code and press the reset button on Ameba. Afterwards, you can see “**Scan Networks**” message appears, with the detected WiFi hotspots and the information of each hotspot.
    wifi-1-2
View all instructions
