Globe.STLThicker walls (~2mm thick), takes a bit longer and uses more filament but slightly better diffusion and probably longer glow if glow in the dark filament is used. Print right-side up at 0.25mm layer height.Standard Tesselated Geometry - 1001.45 kB - 10/07/2021 at 13:44 |
Globe_faster.STLThinner walls (~1.25mm thick) to cut down on material used and print time. Print right-side up at 0.25mm layer height.Standard Tesselated Geometry - 969.81 kB - 10/07/2021 at 13:44 |
Base.STLPrint right-side up. Layer height not critical, but I used 0.25mm.Standard Tesselated Geometry - 567.95 kB - 10/07/2021 at 13:44 |
Top.STLPrint upside down for no supports (or the brim overhang will require adding supports). Layer height not critical, but I used 0.25mm.Standard Tesselated Geometry - 359.26 kB - 10/07/2021 at 13:44 |
