model.jsonAWS IoT SiteWise model definitionJavaScript Object Notation (JSON) - 1.50 kB - 10/25/2021 at 03:31 |
asset.jsonAWS IoT SiteWise asset definitionJavaScript Object Notation (JSON) - 548.00 bytes - 10/25/2021 at 03:31 |
detector-model.jsonAWS IoT Events detector model definitionJavaScript Object Notation (JSON) - 2.57 kB - 10/25/2021 at 03:30 |
input.jsonAWS IoT Events input definitionJavaScript Object Notation (JSON) - 31.00 bytes - 10/25/2021 at 03:30 |
rule.jsonAWS IoT Core Rule definition with 3 actions.You need 4 of these for each CO2 Monitor. JavaScript Object Notation (JSON) - 1.97 kB - 10/25/2021 at 03:29 |
main.cpp (Fan controller)Receives MQTT messages from AWS IoT Core and turns on/off GPIO 26.Modified from https://github.com/aws-samples/aws-iot-edukit-examples/blob/main/Basic_Arduino/src/main.cpp cpp (fan controller) - 9.07 kB - 10/25/2021 at 03:28 |
main.cppPublishes a CO2 value to AWS IoT every 10 sec.Modified from https://github.com/aws-samples/aws-iot-edukit-examples/blob/main/Basic_Arduino/src/main.cpp cpp - 9.70 kB - 10/25/2021 at 03:27 |
Standard Tesselated Geometry - 81.72 kB - 10/25/2021 at 02:08 |
Portable Network Graphics (PNG) - 386.18 kB - 10/25/2021 at 02:07 |
Portable Network Graphics (PNG) - 512.27 kB - 10/25/2021 at 02:06 |
