Ameba Arduino: Use Ameba as Server to Control LED
This project connects Ameba to WiFi and uses Ameba as server, the user can control the LED on/off through a webpage.
In this project, we connect Ameba to WiFi and use Ameba as server, the user can control the LED on/off through a webpage.
For more information:
  • 1 × AmebaD RTL8722DM MINI
  • 1 × Breadboard Electronic Components / Misc. Electronic Components
  • 1 × LED Fiber Optics / Emitters
  • 1 × 1KΩ Resistor
  • 1
    Connect Ameba with the LED
    In a LED, the longer pin is the positive pole, and the shorter pin is the negative pole. So, we connect the shorter pin to GND and connect the longer pin to D13. Additionally, to avoid the electric current exceeds the tolerance of the LED and causes damage, we connect a resistance on the positive pole.
    5-1
  • 2
    Edit code
    Open Arduino IDE.
    Then open “File” -> “Examples” -> “AmebaWiFi” -> “SimpleWebServerWiFi”5-2
    In the sample code, modify the highlighted snippet to corresponding information.
    5-3
  • 3
    Upload and Execution
    Upload the code and press the reset button on Ameba. When the connection is established, you will see the message “To see this page in action, open a browser to http://xxx.xxx.xxx.xxx” in the Arduino IDE, as shown in the figure:
     5-4
    Next, open the browser of a computer or a cell phone under the same WiFi domain, enter the address in the message.
     5-5
    In the webpage, you can turn on/off the LED.
View all 3 instructions
