Final thoughts and links
10/29/2021 at 13:17 • 0 commentsSo for only finding out about the contest with 7 days left, I think I did okay. If I had to do it again, I come up with a more cohesive design for the interior. But, Sid the sandwich Ghost was just too cute not to use. Also if any of you attempt this, a bigger bit of acrylic would be ideal, but it works.
Pumpkin and interior:
https://www.tinkercad.com/things/e6VCuDfendz-e3d-pumpkin
Python script:
https://learn.adafruit.com/pitft-linux-python-animated-gif-player
and done
10/28/2021 at 03:56 • 0 commentsand done
Sooooo Close....
10/27/2021 at 01:42 • 0 commentsalmost there, got my Rpi zero running with gifs on the screen with a python script, and the glass in good spot. still TODO: better screen blocking and bigger gif with fewer frames
POC
10/25/2021 at 04:21 • 0 commentsto test the pepper's ghost I added a LED to the bottom of the pumpkin, and then added the parts that would normally hold the Pi and screen
still waiting on a few things to print, but if I hold a bit of shiny plastic packaging, we can see the LED appears to be floating upright in the pumpkin
We have a shell
10/24/2021 at 20:49 • 0 comments![]()
main shell completed, over 48 hours of print time so far. inside painted with matte black and outside given a little dry brushing
TechGirl
