Interface IR Obstacle Avoidance Sensor & arduino
In this project, we are using E18-D80NK IR Proximity Sensor which we will interface with Arduino.
0 followers
The project describes how to interface IR Obstacle Avoidance Sensor with Arduino prevents the sensor from the interferences caused by the normal light of the sunlight.
E18-D80NK IR Obstacle Avoidance Proximity Sensor
The E18-D80NK is an IR Proximity Sensor with an obstacle detection range approx 3 cm to 80 cm. The utilization of modulated IR signal prevents the sensor from the interferences caused by the normal light of the sunlight.
E18-D80 IR Sensor is generally utilized in robots to avoid obstacles. The detection range can be adjusted as per the application with the help of the multi-turn screw that is placed at the back of the sensor.
For the connection of Interfacing of E18-D80NK IR Sensor with Arduino, attach the Brown wire of sensor with Arduino 5V pin, attach the Blue wire of sensor with Arduino’s Ground and attach Black pin of a sensor with a digital pin 7 of Arduino Nano.
  • 1 × E18-D80NK IR Sensor
  • 1 × Arduino Nano R3
  • 1 × Jumper wires (generic)
  • 1 × Breadboard (generic)
  • 1
    Run a Program
    const int e18_sensor = 7;
    const int led = 2;
    void setup() {
    Serial.begin(9600);
    pinMode (e18_sensor, INPUT);
    pinMode (led, INPUT);
    void loop() {
    int state = digitalRead(e18_sensor);
    Serial.println(state);
    if(state==LOW){
    Serial.println("Object Detected");
    digitalWrite(led, HIGH);
    else {
    Serial.println("All Clear");
    digitalWrite(led, LOW);
    delay(1000);
View all instructions
