BOM Calculator.xlsxExcel sheet to calculate BOM, because I wanted to make more than 1. Use the amount at the top and the last column to note how much you needsheet - 10.75 kB - 12/17/2021 at 22:41 |
PhalanxCase_Rev9.stlCase 3D model, directly printable without supports.Standard Tesselated Geometry - 2.50 MB - 12/17/2021 at 22:40 |
EasyEDA_Phalanx_Schematics_PCB.zipEasyEDA importable format for Schematics & PCB. Can be used to generate Gerber & BOM.Zip Archive - 222.77 kB - 12/17/2021 at 22:23 |
