Sensor connector pinout
A project log for RUDDOG RP691 2200kV characterization
Since datasheet for this BLDC motor is not available, I will try to characterize its properties and share it here.
kevarekkevarek 02/13/2022 at 13:180 Comments
Pin 1: Supply voltage (both 3V3 and 5V tolerant).
Pin 2: NTC thermistor output (with respect to GND). 10kOhm @ 25 °C; Beta unknown for now.
Pin 3: Hall 1 output. Open drain. Seems to be related to Phase A.
Pin 4: Hall 2 output. Open drain. Seems to be related to Phase B.
Pin 5: Hall 3 output. Open drain. Seems to be related to Phase C.
Pin 6: Common ground.
