The Wolf and his Cub
A project log for Wolf
Use a Jaguar or SNES controller as a joystick and a keypad in Atari 2600 and 7800
danjovicdanjovic 03/28/2022 at 00:560 Comments
Despite being possible to use off the shelf components to make DIY reproduction easy, I am not satisfied with the design.
Then I worked on a shorter version of the board that uses the DB-9 replacement cord directly soldered to the board. Same goes for the SNES connector, that should be make of a severed extension cord.
This alternative design fits into a Hammond 1593J box, that is cheaper and smaller.
