SPI works for yanking off a flash dump. (that means that the port is not locked at all)
Pins on the chip for tracking down the SPI are following:
Left side:
3rd from bottom: CS
4th from, bottom: MISO
5th from bottom: MOSI
6th from bottom: CLK
Noticed that they are wired out on a undocumented extra set of Pins in the micro-USB connector.
