SPI works for yanking off a flash dump. (that means that the port is not locked at all)
Pins on the chip for tracking down the SPI are following:
Left side:
3rd from bottom: CS
4th from, bottom: MISO
5th from bottom: MOSI
6th from bottom: CLK
Noticed that they are wired out on a undocumented extra set of Pins in the micro-USB connector.
Waiting for a CSR USB-SPI Programmer since the SRL2 got a obvious SPI Port.
(the 10S only got TP1-TP10 and no meaningful names)
SRL2 is my main helmet intercom, thats why i dont want to mess much with its firmware. Got to find out which chipset pins are the SPI ones to rigg a connection jig for the 10S which i bought for development/reverseing
Peeking into the Hardware (disassembling the SRL2 main unit is really easy since its only 4 screws holding it together) helped me finding out it being a CSR device.
Understanding the outer firmware file format was easy after spotting the pattern in the header. Each file inside is MD5-summed and stored with offset and length in the header.
Split Layout Headsets got a DFU file for the internal flash and a vp.bin for the external flash. Only those can be modified so far since (found out later) the external flash is not signature-checked.
Extraction of the external IMG is possible with the ADK toolkits since its a Filesystem image in their format.
Current workflows are written into the linked Github code
