Printed parts:
other parts:
| parts | quantity |
| M3X30 | 6(at least) |
| M3X8 | 4 |
| M3X14 | 4 |
| NEMA stepper | 1 |
| M3 nuts | a few |
Insert a nut to BASE_motor_input_gear:
put the motor gear to the stepper.
The hole is too tight, so I'm using a vise to push the gear to the motor.
M3X3mm set screw to secure the gear.
4 M3X8 screws to mount the stepper.
apply 5mm ball to the slew bearing parts.
Don't put too many balls here. Little gap will be fine.
A little grease (lubricant) will be great.
Put those parts together.
put 2 of M3X30 screws in there but don't go too much, we need another part.
Put 12 nuts in the outer nut-holes.
fasten the screws, done.
Andy
