[R] Information for galvanised pipe + key clamps
A project log for SecSavr Sublime [gd0036]
An FDM 3D printer that I described as "The FULL Coverage, Extended X, Pro Max, Ultramatrix Solution".
kelvinakelvinA 03/06/2022 at 18:500 Comments
https://keesafety.co.uk/images/uploads/uk/documents/Kee_Klamp_Tech_Spec.pdf
This is a PDF outlining safe maximum limits for key clamps, which I'll be using with 42.4mm galvanised pipe.
